How much to remove in ground oil tank?
Sep 29, 2004
18,656
68
I just founf a potentail "hot deal" in town. They jsut reduced the price of this place. Location is OK to awesome depending on what we do to it.
Anyways. it has an inground oil tank, which is probably why it isn't selling. how much to yank one of those out?
Only concerned wtih removal at this point. I would have the tank tested for leaks as a contingency so assuming I have soil to clean up.
-- EDIT --
Today I ran into a friend at work. his brother does this kind of work, albeit half way accross the sountry. I asked him what clean up costs arounf here. He said $750 per 55 gallon drum. That's probably half of a yard, so $1500 per yard! That can add up VERY quickly depending on the severity. I think he said one gallon of oil tpically requires the removal of one barrel. So if a tank leaked 50 gallons over 10 years say, that's 25 yards of dirt to remove. Or $37,500! When he mentioned this, I would assume this is how his brother does estimates. The true amount needed to remove is ultimitely decided by the EPA. So, it's remove what you think is contaminated, have EPA retest the soil. REPEAT till area cleared.
So, the house is pretty much a tear down if the contaminaetd area is near the foundation. So, one might as well expect to typically be buying the lot plus a headache ($$$). The lot is in an almost perfect location though.
RU482
12,689
don't know off the top of my head, and I'm sure it varies regionally.
Call a couple excavation companies
good luck!
DainBramaged
23,454
41
We had an inground oil tank, assuming you are talking about the type for furnaces? It's still there. :)
blackdogdeek
14,453
10
we almost bought a house that we found out had a buried oil tank. seller didn't originally divulge info. we had the ground tested ourselves and it was contaminated so we bailed.
not sure if seller ever had it removed but i think when we called around it was on the order of $15k to remove it but don't quote me since my wife did most of the research.
35,200
Call your state's UST program and ask them for a ballpark figure and if any assistance is available. Specifically ask if any "brownfields" money might be available.
Sep 29, 2004
18,656
68
Wow, AWESOME REPLIES.
To answer the question of why. The place is a fixer upper. It was just reduced in price. From $625K to $490K. It easily needs $50K-$100K put into it. The killer is the oil tank though. If that's a big problem, I have a big problem.
But! This is in a VERY good location and once it's fixed up, it would fetch $700K+. So, if I can get it fro $450K, put $70K in new amenities into it while resolving the oil tank issue (why it's probably not selling) for $30K tops. I could profit $200K+.
Also, what is "UST"?
blackdogdeek basically explained our fears. I'm assuming the place originally had an unknown remark for the oil tank condition on the disclsoure sheet required by law. Someone made a contigent offer and it's no longer somethign that can be claimed as "unknown". Thus the drastic drop in asking price.
The stigma it bring could cause hte price to drop to $400K though.
If I had the money though, it's a tear down/new construiction. The lot alon is worth $1,000,000 if you ask me. A 2500 sqft home on that lot, nicely done would fetch $1.5M+
Sep 29, 2004
18,656
68
Originally posted by: crab
Why do you want to remove it?
In ground oil tank made of steal+moist soil+ time = rust
which implies contaminated soil.
There is a reason, in ground oil tanks are no longer done ;)
35,200
Sorry about that, I used to be a pinhead bureaucrat. UST is Underground Storage Tank. Most states have a program, usually in the Dept of Environmental Protection or Environmental Quality or Natural Resources (the name varies by state) that monitors cleanups of leaking underground tanks. For qualifying sites, the state will pay for part or all of the cleanup. Brownfields refers to the re-use of contaminated sites. Sometimes funds are available for that or in some states there is a tax break for taking on a brownfileds site.
So
25,923
17
Just...random thought...why not seal off the pipe connecting to the home heater....pump all the oil out...and fill w/ concrete? The concrete will push and leftover oil out, stabilize the tank, and concerte is not harmful to the surrounding soil...
Sep 29, 2004
18,656
68
Well, I found good news and bad news.
Tank with no leakeage. Depending on location, deph, etc. It costs about $2,500 tops to remove it.
removal of contaminated soil though. That's the b!tch.
Sep 29, 2004
18,656
68
I just read up some info.
Unless taking it out jeperdizes the home, it must, by law be required.
if it is left in place, it still needs to be preofessionally emptied. Then filled with pea gravel or sand.
alm4rr
4,390
sounds like a neverending epa nightmare that will haunt that property for decades
that inground tank is probably just one lil thing they told you about... what the didnt say whas that there are probably a dozen other buried barrels under that you won't find until digging up the other one and will cost additional $$$
expect the property to be sold as is, and forcing you to sell it as is from there on out
Sep 29, 2004
18,656
68
NMo, it's one in ground oil tank. It's just like the typical 500 gallon tank in your basement if you have oil heat. They are always above ground. In teh old day, people put it underground for some reason.
