How much to charge for a backup/format/re-install?
FoBoT
63,084
15
fobot.com
charge enough so that they will tell you no
you'll be chained to them for tech support until 4 years AFTER they die
FoBoT
63,084
15
fobot.com
Originally posted by: Toastedlightly
Ask best buy or local major retailer/repairer. Undercut them by ~1/4
bad, bad , bad idea. take what BB or whoever charges and DOUBLE it so that they won't ask you to do it and they will go to BB or whoever. you'll be chained to fixing every problem they have after you "Fix" it for them
djheater
14,637
Yep.
They have about 30 programs which they *ABSOLUTELY* must have and have forgotten about... They'll remember them slowly over a period of several months and they won't have any idea where the installation disks are, they probably won't even remember the name of the program, but they'll certainly call you to see if you can help them with it.
Ausm
14
75 bucks if they have money and are nice
125 if they have money and are an asshole
35 if they have limited funds
Ausm
pancho619
2,467
I usually don't charge my friends for stuff like this, but if they insist I tell them whatever they think is fair....they usually cough up anywhere from $50 to $100 depending on the person.
Dec 27, 2001
11,272
I don't touch anybody's computer outside of work.
But if you're Mr Wizard Master desktop support guru with incredible luck, then I'd do it, but I'd do it for nothing since it's your wife's co-worker and then she'd owe your wife and would feel obligated to return the favor with a flaterring comment infront of a boss or something.
cbeavers
191
I do side work like this all the time. I normally charge 75.00 for the reconfig and 25.00 to save all data.
I haven't had anyone complain that it's too high, so that's what I would do.
