How much soil and space for a small indoor plant?
AgaBoogaBoo
26,108
I'm building something and need to estimate how much space with soil a basic indoor plant might need - right now I'm keeping 4"x4" and a 2" depth in mind, does this sound fine?
If not, what should it be?
Edit: I guess this is beyond vague... Maybe I should ask what kind of plants would work well in this much space? Or just go to a store and see what comes in small containers?
FoBoT
63,084
15
fobot.com
that is very small, most plants have roots that go deeper than 2"
if you want a tiny plant, you can get some small cactus or just go to the nursery and ask for something tiny first
AgaBoogaBoo
26,108
Hmm... I'm wondering what size I should make it then, I hadn't really thought about this as much as I should have maybe. Any recommendations on depth? 6 inches?
Bryophyte
13,430
13
With a pot that size, you are stuck with small cacti and succulents, pretty much. Use the right soil type for the type of plant (cactus mix for cacti and succulents, for example.) Make sure the space you plan on putting it has the right light and temperature conditions for the plant you want.
AgaBoogaBoo
26,108
Originally posted by: SSSnail
Will you be needing high output lamps as well? ;)
:D
I hadn't thought about lighting yet, but it's a good point, that'll be the next step.
That reminds me... I had some PM's about flashlight products that I forgot to reply to, need to get working on those
preCRT
2,340
123
What type of plant are you interested in? You must have some kind of thing in mind. If you give us more details, you'll get more help.
FoBoT
63,084
15
fobot.com
most pots are pot shaped for a reason, the plants roots go down and out anywhere from half to fully as tall/broad as the plant above the surface is, depending of course, a corn plant doesn't put roots down 7-8 feet
but i guess you are thinking of a flower or house plant
pansies are nice small flowers, one should be ok in a 4"x4" and 4" deep soil space
AgaBoogaBoo
26,108
Originally posted by: Bryophyte
What are you making the container out of?
Plexiglass - this will have an "island" in the middle with a plant, preferably something like a small tree. Around it will be water, enclosed off by more plexiglass obviously so it doesn't mix with the soil, and then it will have a mister like a humidifier/vaporizer. I need to think about the dimensions and such, I was hoping to make almost a mini jungle or something with a few small tree like plants.
I think before I do any cutting or deciding on dimensions, I should go to a nursery and pick out plants.
AgaBoogaBoo
26,108
I was originally thinking of a bonsai tree and so I picked up a few books on them, but left them at school before coming back!
AgaBoogaBoo
26,108
If I go with a bonsai tree, what kind of depth should I allow for it? Or does that depend on the species as well?
Bryophyte
13,430
13
You don't seem to be taking into consideration drainage. If you make the plant portion with no drainage holes, plan on sizing it to drop a potted plant in, so you can take it to the sink to water it and let it drain before putting it back into the container.
AgaBoogaBoo
26,108
I was actually already planning on holes on the bottom for drainage and a little crate for it to sit on for drainage. I need to think about how I'll slope it though so it actually goes into the hole.
Bryophyte
13,430
13
You need to also make sure that the mister doesn't cause disease problems. Many plants are susceptible to things like powdery mildew that thrive in highly humid environments. You might consider orchids, they like to have dry feet but humid air.
Bryophyte
13,430
13
Ah, from your description above, I pictured water being around and below it. Doh.
AgaBoogaBoo
26,108
Ah good point Bryophyte, I need to figure out how to work with that. I also need to think about soil composition, maybe pea gravel at the bottom?
AgaBoogaBoo
26,108
Here's a picture: http://img45.imageshack.us/img45/8427/plantuc9.gif
Green are the plant(s), brown is soil, and blue is obviously water.
There's a lot more involved in this than I thought, to do it properly anyway, heh.
How do I deal with mildew and disease issues?
liquid51
284
You could also choose a plant that thrives in low/partial light. Orchids, while rather expensive, are a partial light flowering plant. They require very little watering, the blooms last a very long time, and they are incredibly nice looking plants. I just bought a yellow orchid for my wife for valantines day.
Here are some general orchid pics: Bloom, full pic
My wifes yellow has a bloom just like the first pic; I love it. Google image search for more pics; there's an almost endless variety. And while being expensive, I think they may actually be more affordable than bonsai and would also maintain an asian decorative style.
Bryophyte
13,430
13
Bonsai don't need a lot of soil depth, because the goal with bonsai is to stunt the growth of the plant, but they do require very frequent attention to root and stem pruning, keeping soil conditions ideal (amount of water and fertilizer) as well as whatever light and temperature conditions the specific plant needs. I've never seen a bonsai grown in a clear container, so I don't know what affect the exposure of the roots to light will have on it.
Bryophyte
13,430
13
Another consideration is how you're going to control algae in the water without exposing the plants to something that'll be toxic if you're using the same water for misting.
AgaBoogaBoo
26,108
I'll have tons of java moss in there, that should help a little bit I'd imagine. Would putting a snail or something in there be a bad idea?
