Depends if it's load bearing or not. If it's not load bearing, I'd say under 1k. The cost will be in fixing up the floor and ceiling where the wall was. May have to repaint the whole ceiling after. If there's texturing that adds to the work. Floor, it depends what's there on both sides. May have to redo a whole side to make it match. To minimize on dust cut large sections of drywall and try to get them off clean. Sure it's more fun to just go at it with a hammer but that just makes a huge mess.
If it's load bearing, then you're probably looking at getting an engineer involved if you want to do it right. Even Holmes usually brings in an engineer for stuff like this. Though if you want to save from that, just be sure to put in a beam and make sure what is holding the beam there is as strong if stronger than the beam itself. You can't just stick a beam anywhere, it has to be supported and what is supported has to be able to support what the beam supports. Common sense... yet some people do not know this. "Bah just sister a couple extra joists". On what? The 2x4 stud wall on both sides? Not enough.
To get an idea if it's load bearing, is it perpendicular to the joists? And do the joists end at that wall, and new joists start? That's a good indication. If you are not sure, assume it's load bearing, or get an expert. Load bearing walls will normally be in the center of the house too, but you can't just go by that.
Yeah it does appear to be load bearing to me, and wouldn't mind having the beam. What would be the typical cost to have a contractor do that?
Could get pricey. Those beams can get expensive. Not to mention they will have to either break into wall to set the beam, or add posts. If you add posts, you are looking at wrapping them up in drywall or paneling. My guess would have to be non-union. You are still looking in the neighborhood of $5k. Of course red squirrel is correct in it could be more cause you could have texturing on the ceiling and such. And it also depends on the flooring. It is a pain if you have wood/tile floors.
The height of the wall doesn't have much of an impact on cost - it's the length of the wall. I'm not a contractor, nor have much experience with such a task (helped with that, once about 30 years ago as a teen.)
At the ceiling, provided you can do the work without damaging the ceiling, you won't have a tremendous amount of finishing expense, beyond the beam & boxing it in.
Now, inside the wall, electrical wiring. If the wiring runs up to the 2nd story (if there's a 2nd story), then you're going to have some rewiring to do - not a major problem though. If there's any plumbing in that wall, say supply lines to a bathroom - now you're stepping up, in possible problems - hopefully, you have other interior walls that you can run the new plumbing through (you don't want to run through an exterior wall, at least in the north where the lines would be more prone to freezing.)
The floor. HUGE variation in prices here. Carpeting? You're probably going to have to recarpet. Wood flooring? Again, it's going to depend. I think that if in both rooms, the wood flooring is running perpendicular to where the wall was, and if both rooms have the same type of wood flooring, then you might be able to cheat and install an accent strip of wood where the wall used to be; something that denotes a sort of separation into two areas. If you don't want that, and instead want to blend the floors together to give the appearance of one unified area, then you're talking a bit more money AND need to be able to get matching wood flooring.
Total cost? Are you talking just materials? Are you going to do it yourself (do you know what you're doing?)
Anywhere from $500 (you do the work, no rewiring necessary (would be a miracle), box in the beam, have the tools, have necessary materials to brace ceiling while installing the beam, etc., and lucky that you can do flooring cheaply by putting in an accent strip; to $15,000+ (contractor & worst case scenarios.)
There is electrical wiring in there, no plumbing, and I probably would elect for matching wood panels on the floor. So up to $15k huh? Wow a lot more than I thought it would be
Buy a sledgehammer, go to town. 30 bucks or so.
Hey, you said knock a wall down, nothing about making it pretty![]()
can you take pics of the wall on both sides for me? I need to see how many switches/outlets and the locations as well as the joints where it meets the ceiling, floor and other walls.
I can give you an estimate
<~~~~~Did Construction for several years, went to a trade school for 3 and have friends/family all in the business.
I wanna open up the family room to the dining room
What about partially opening it up, with a door and bar?
Something like this, maybe?
This is very rough layout of the floor plan and the wall I wanna take out
