How much should it cost to frame a 16x20 photo?
djheater
14,637
I have a nice picture of my girls in this HUGE format... I like the frame store at pictureframes.com... the Interactive shop allows you to get a look at what you're buying, and that's neat.
Anyway to mat and frame the picture comes out to about $55 including the $10 in shipping.. :|
Does that seem about right?
<----framing n00b
mugs
48,920
46
That's really cheap. I'm looking for a frame/mat about the same size, priced it up there, then went to Michael's and the price was $220. Michael's always has 50% off deals, but even that is twice as much as pictureframes.com
Edit:
My frame is actually 11x20, so figure yours would probably be substantially more at Michael's
If you want something cheaper, you could get a pre-made frame that's approximately the right size and crop the photo. You could get them to cut the mat at pictureframes.com
Also, I'm not sure if the frames come with glass at pictureframes.com, so take that into consideration. The glass would probably be about $10
djheater
14,637
Alright... I guess I'm a cheap fvcker...
Hell I got the print for free from my sister in law.. why should I complain.. :D
djheater
14,637
Edit:
They won't ship glass.. the price I quoted includes non-glare plexi and corrugated backing...
mugs
48,920
46
No, custom-made picture frames are just surprisingly expensive. :)
Anubis
78,712
427
tbqhwy.com
yea thats really cheap, my sister had a 20x30 print i gave her framed with glass and it cost nearly 400$
