Originally posted by: frostedflakes
Not exactly what you were looking for, but according to first Google link I found, breakdown voltage of air is approximately 3kV/mm. I'd assume this is for dry air, though -- higher humidity may significantly decrease resistance and breakdown voltage.
So that would be 3 MV??
3MV to start it, much less to maintain ... this is actually really bad because once you get your arc you'll probably wreck your power supply.
Look up some info on jacob's ladder.
two wires next to each other, verticle. Close at the bottom, far apart at the top (like a V).
the arc starts at the closest point, of course, at the bottom. The superheated plasma that is conducting the current rises in air, and the arc continues up to the top of the ladder, an area that was too far apart for it to start the arc due to the breakdown voltage of air, but once it's got the arc it can maintain it there.
it does, however, keep going up until the arc climbs off the ladder and dies, and then restarts at the bottom.
What you want to do would require immense power. I don't even think those giant diesel welders you see at construction sites could maintain a 1-meter arc. That's huge.
Originally posted by: ICRS
So then lightning must have a lot of power to be able cross miles of air.
Originally posted by: Shadow Conception
Wait what, I thought resistance was measured in ohms.![]()
