FX8120 TDP = 125W
5970 TDP = 294W
5870 TDP = 188W
= 607W max. +12V load at stock
Not quite. TDP does not indicate a maximum consumption , but rather a design limit. Actual maximum consumption usually is lower.
Actual maximum is the maximum amount of power going through the card at stock settings.
No Even if you overclock extreme TX850 can handle it easily.TX850 will be fine as long as you don't overclock the cards and that FX-8120.
How do you measure "actual maximum"?
Cutting it very close. Strongly not recommended. May fail in a year or two even at stock.
I wouldn't do that setup without a solid 1000w for stock and 1200+ watts for good oc.
I fail to see how OC plays any factor, since he said "OCd @ stock voltage." What I would make sure is to have a better quality PSU, rather than needing something with more maximum power - something Gold standard or better.
I haven't looked too much into the setup, but I would think that something close to @lehtv initially posted, would be true. With PSUs, it's the rails that you have to make sure you have enough current - pay close attention to the Voltage rails and what amperage is allocated to them. You can buy a 2000W PSU, which still might not meet your requirements.
Really? A year or two? So you'd bet money it won't live past year 2? Where do you make this stuff up from?
