This is really something you are going to have to do for yourself. Anyone who tells you 'yes' or 'no' without knowing every single spec is making something up.
However, this is not as difficult as it may seem. Power (watts) equals current (amps) times voltage. All you have to do is find the specs for your power supply and then add up the numbers for your devices.
Now there is one more caveat - the power supplied is different for each 'rail' (or specific voltage) available in the power supply. The 300W is a total figure for all rails - +5, +3, +12, -12, etc, so keep this in mind when adding up numbers, you will have to find the specs for your PS and see how much is devoted to each rail.
For example, I am building an Athlon XP machine in a microATX case where the biggest power supply available is 200W. Crazy, you say? Well, I talked this over with the engineer of the power supply and we decided that 200W was actually more than enough. Here's why.
The 1900+ draws 34.7 amps (I) average and 38.9 amps max (this CPU info is available from AMD and Intel web sites). The core voltage (Vcc) of the Athlon XP is 1.75v. So, the power requirement just for the processor alone is (rounding up) 40A x 1.75v = 70W.
Now, we need to know that the Athlon core runs off the +5v rail of the power supply, and that the combined output for the +3v and +5v rails is 130W. As you can see, there is more than enough available for the CPU.
Now all I really need to do is add up the other stuff and I can see that I am in good shape with the 200W PS. Good luck to you.
