Originally posted by: PCI 2.2 specs
4.3.4.1. Power Requirements
All PCI connectors require four power rails: +5V. +3.3V, +12V, and -12V. Systems that provide PCI connectors are required to provide all four rails in every system with the current budget specified in Table 4-10. Systems may optionally supply 3.3Vaux power, as specified in the Pi 7 Bus Power Management Interface Specification. Systems that do not support PCI bus power management must treat the 3.3Vaux pin as reserved.
Current requirements per connector for the two 12V rails are provided in Table 4-10. There are no specific system requirements for current per connector on the 5V and 3.3V rails; this is system dependent. Note that Section 4.4.2.2. requires that an expansion card must limit its total power consumption to 25 watts (from all power rails). The system provides a total power budget for PCI expansion boards that can be distributed between connectors in an arbitrary way. The PRSNTn# pins on the connector allow the system to optionally assess the power demand of each expansion board and determine if the installed configuration will run within the total power budget. Refer to Section 4.4.1. for further details.
Table 4-10 specifies the tolerances of supply rails. Note that these tolerances are to be guaranteed at the components not the supply.
Table 4-1U: Power Supply Rail Tolerances
Power Rail------Expansion Boards (Short and Long)
5 V ±5%--------5 A max. (system dependent)
3.3 V ±0.3 V---7.6 A max. (system dependent)
12 V ±5%------500 mA
-12 V±10%----100 mA
