- Aug 29, 2004
- 6
- 0
- 0
Ok, so I posted earlier regarding this same computer and you guys really helped me out. Thanks a lot! Now I need to solve the original problem. I got this mondo-cheapo case that came with a "LeadPower" power supply. Supposedly a UL certified 550 W PSU. Well the computer needs to run 4 7200 RPM HDs, several case fans, a 3.2 Prescott core P4, a GeForce 5600, 4 GB RAM, a floppy, and 2 optical drives. Well anyhow, 550 watts should be WAY more than enough, but this thing is so cheap the whole computer shuts down after under a second if more than a single drive is connected to it. Apparently it's hold under a load is really bad. I'm getting an Antec (or another brand if recommended). I really think 430 should be enough. Some other guys said it ran a similar setup all right. Opinions?
Thanks a lot!
Thanks a lot!
