How much power for a Duron 750MHz @ 900MHz?
Hyudra
897
I had it set at 1.60Volts, and it seemed to run fine, but when I tried to reformat, it wouldn't work. Now I set it at 1.75Volts, just to be safe, what do you guys recommend?
wesmaster
18
Go to 1.85 you can simply hit 1GHz
Find the good heatsink. try to control temp as low as you can,
any below 50'c will be consider 'SAFE' ?
Duron850@1050 (10x105 vcore:1.82 idle:42'c f/load:45'c)
(can hit 1000 at 1.75vcore)
G/W FOP38
MSI K7T Turbo-R
448MB RAM Kingmax PC-150
GeForce2 MX 200c/190m
ATA-66 7200rpm
