I have a Dual system that i am building based on p2 450's , but the case that the chips are going has a ps that is rated @ 276watts. Is this enough to run the dual system for the time being? (2months)
i have an 83W dell PS running:
PIIIE 500mhz
96mb PC100
voodoo3 2000 @175mhz
7200 rpm 10gb hdd
soundblaster 64V
D-Link 10/100
48x cd-rom
zip 250 IDE
floppy
2 80mm case fans
one 50mm(i think it's 50mm, not sure) fan on the voodoo's heatsink
run's just fine
so i'd bet that 276W will be more than enough
