How much power does a typical PC consume?
brigden
8,702
My brother likes to leave his PC on 24/7. My dad complains and claims it costs a fortune. How many KW/H would a PC consume?
CraigRT
31,440
it's not very much....
about as much as a 60W light bulb or something
CRT monitors take more than LCDs too.... gotta take that into consideration.. the actual PC itself I would imagine uses less juice than a big CRT monitor.
zephyrprime
7,512
$15 a month. There was a guy here that actually put his computer on a power meter. It consumed about 160watts. Add another 100watts for the monitor. So,
160 + 100 = 0.26 Kilowatts
0.26kilowatts * 24hr/day * 24days * $0.08/(kilowatt hours) = $14.77
A lot of the the figures people throw around that are really low date the 286 era. I heard them back then and they still haven't changed.
RU482
12,689
I've got a watt meter and a 3Ghz P4 machine w/ a 17in CRT at work...shall I measure the power consumption and calculate the energy cost?? :)
It wouldn't be a cumulative amount, but rather calculated from a steady state reading. Stay tuned
sillymofo
Banned
Aug 11, 2003
5,817
Originally posted by: zephyrprime
$15 a month. There was a guy here that actually put his computer on a power meter. It consumed about 160watts. Add another 100watts for the monitor. So, 160 + 100 = 0.26 Kilowatts 0.26kilowatts * 24hr/day * 24days * $0.08/(kilowatt hours) = $14.77 A lot of the the figures people throw around that are really low date the 286 era. I heard them back then and they still haven't changed.
But your monitor isn't on all the time... so take some off which is about what M4H said, about 3 bucks.
orion7144
4,425
But don't forget that if you have the energy saving mode turned on for your CRT you can save about half of that. And if it is a LCD it uses even less.
brtspears2
8,660
I did my research on this, using my own computer and comparing power bills. The month where I turned off computer 2/3rds of the day, I saved $15 over the previous month.
draggoon01
858
please do. it would also be useful if you measured during full load and when idle.
orion7144
4,425
That is hardly a good comparison since the temperature outside dictates the electricity costs more than a PC. So in your research every day of the month the temperature would have to be the same as the last month and not just highs and lows but every min. of the day the temp would have to be the same.
Eli
Super Moderator | Elite Member
8
There is no way to tell without knowing your exact system specs.
You have to add up all the watts(which is hard for some things, like the motherboard, you just have to research and guesstimate), and calculate your kWh.
Unless it is a very high end system, it's probably not too bad.. but it can add up quickly.
Confused
14,166
Originally posted by: Zugzwang152
Originally posted by: Talon02
1.21 gigawatts, no wait, thats only if equipped with flux capacitor.
why oh why did i laugh at that :(
Probably the same reason that I laughed at it too :)
Confused
Zugzwang152
12,134
Confused
i am terrified by the thought of a PC that consumes 1.21 gigawatts of power... :Q
and i'm terrified of the percentage of ATOT'ers who actually understand the joke up there....
BigJelly
1,717
Confused
everyone needs a "Mr. Fusion"
RU482
12,689
OK, checked out my system
Monitor only, in "power saving mode" - 4W
PC, in shutdown mode - 1.75W
PC + Monitor, steady state - 125W
PC only, steady state - 60W
PC + Monitor under full load with two Distributed Folding clients running - 180W
PC only under full load - 120W
This is way less than I thought it would be. I'm running a Dell Dimension 8300, FWIW.
Anyway, 180W = .180kWh x 30 days x 24 hours x $0.08 per kWh = $10.36/mo to run this machine at full load 24/7 with the monitor on
draggoon01
858
what are your system specs? cpu, ram, hdd, video card, etc...
dxkj
11,772
Around 10 a month if you are running a DC client, if you are into power saving modes it gets lower... but probably 5-15 depending on motherboard and use.
Univac
306
Originally posted by: redly1 I've got a watt meter and a 3Ghz P4 machine w/ a 17in CRT at work...shall I measure the power consumption and calculate the energy cost?? :) It wouldn't be a cumulative amount, but rather calculated from a steady state reading. Stay tuned
OK, checked out my system Monitor only, in "power saving mode" - 4W PC, in shutdown mode - 1.75W PC + Monitor, steady state - 125W PC only, steady state - 60W PC + Monitor under full load with two Distributed Folding clients running - 180W PC only under full load - 120W This is way less than I thought it would be. I'm running a Dell Dimension 8300, FWIW. Anyway, 180W = .180kWh x 30 days x 24 hours x $0.08 per kWh = $10.36/mo to run this machine at full load 24/7 with the monitor on
I've allways wondered about this, Thank you for taking the time and testing it! :cool:
However, I wish I only paid .08$ a KWH.... :(
