Originally posted by: glen
My PC was built in 2003, and I have never kept a PC this long. Usually I update or tweak it every 2 to 3 years.
Do we need to get quad core or Vista?
Need Niether..
There is a Custom Crysis PC on sale for $700. They've (including crytek) sponsored this pc and they put XP on it. So that says something... and its only a dual core too.
If that's in your budget, I'd consider that since it is tweaked for gaming and designed as a budget gaming pc.
You don't really NEED a quad core. A faster core2duo would be fine. I'd opt for a dual core with faster memory than vice versa.
Wow - has everyone seen this:
http://farcry.us.ubi.com/index.php
I need a machine that will play that!
Really? The game LOOKS so much like FarCry, I just assumed the engine was simply the next level of whatever engine it was, Crysis I think right?Originally posted by: gorcorps
Now Crytek isn't involved in Far Cry 2 so I don't think they're the same engine, but it should be fairly comparable.
Originally posted by: BladeVenom
Far Cry 2 is also being made for consoles, so the system requirement to run it will be a lot lower than those for Crysis.
