- Nov 9, 2000
- 5,388
- 1
- 0
Yesterday I tried to change the oil in my wife 11 odyssey. After draining out the old oil I couldnt get the damn filter off. The filter cap kept slipping even though it was supposed to fit. After trying for a while I decided to put new oil in and change the filter later, after I get a different tool to do the job.
Now my question is how much oil will come out if I remove and replace just the filter? Or should I drain the oil first to re-use after changing out the filter?
thanks
thanks
