How much of an effect does room temperature have on cpu temp?
dennilfloss
Past Lifer 1957-2014 In Memoriam
Oct 21, 1999
30,509
12
dennilfloss.blogspot.com
Is it linear? Does a room temperature of 30C(86F) (e.g. my appartment this afternoon :() translate roughly into a cpu temperature of 10C(16F) more than a room temperature of 20C(68F) providing that case airflow is adequate? I assume that the effect is compounded if airflow is insufficient.
Waiting for the landlord to turn down the bloody heat. :eek:
Mikewarrior2
7,132
It is linear to a point... Roughly, yeah, with good airflow, a 10C increase is about a 10C increase in cpu temp, since the heatsink is using case-temp air to cool itself...
Mike
dennilfloss
Oct 21, 1999
30,509
12
So a full load (24/7 rc5) cpu temp of 56C in a 30C living room for an AJFA ('B') Tbird 1@1.1GHz on an A7V133 (rev. 1.05, bios 1.003) would be roughly equivalent to ~46C in a 20C room?
That makes me feel a bit better. I though that my Taisol GCK 742092/YS Tech HSF combo was performing very poorly even with Arctic Silver because I see so many reported temps in the 40s. Looks like my room temp is the main culprit. :)
Thanks Mike. :)
nolamerz
188
my cpu is consistently about 13-14C > case temp, which runs about 2C over room temp. using a free crappy 2 inch thermometer to measure room temp, so my readings are estimates. on a kk266 with 1.33 amd
