Originally posted by: Roguestar
Ok, there is a load of FUD about the Pentium Dual Core series of processors floating around right about now.
Originally posted by: ther00kie16
I've read some opinions that the Pentium Dual Core CPUs for laptops are closer to what would be a dual core Celeron (btw, Celeron M's for laptops are still single core) so they are significantly slower than the Core duo or Core 2 duo. However, for basic apps, any modern day dual core will do. Cheapest X2 laptop is probably $399 depending on the week while cheapest Pentium dual core is $499 and Core 2 would be $599 (or cheaper online). I recommend a Core 2 for <$600 online as it would be much faster than the other 2 alternatives. Also, if you can wait that long, Black Friday isn't too far away.
The Pentium "Dual Core" series consist of laptop and desktop processors.
The Pentium "Dual Core" series is based upon Allendale and Wolfdale microarchitecture, both derivatives of Conroe and Penryn respectively, and have very similar clock-for-clock performance to "full" Core 2 Duo branded CPUs.
The Pentium Dual-Core CPUs for desktop and laptop perform slightly better than what would be an equivalent dual-core Celeron, as the Celeron is also based on a watered-down version of Core 2 microarchitecture, with further watered-down FSB and cache. This was more or less correct in your post, but contextually misleading.
They perform better than the Core Duo range of laptop processors (and infact were designed by Intel to replace them as a Core 2 based laptop processor), and are of almost comparable performance to the Core 2 Duo range, though they have slower FSBs and less cache.
In a laptop, for
"university work and home multimedia stuff.. No gaming or anything too intensive", a Pentium Dual Core CPU is
more than enough processing power.
