GratefullySaved
OK PC People, the Macintosh man of mighty moronic musings is confused again....😉
I'm looking to upgrade my gaming machine Abit KT7a mobo (1.2 ghz Athlon, 512 MB PC133, 40 GB 7200 HD, SB Live, blah blah and yawn for the rest of the specs), but I'm looking to do this on a really tight budget...I want to buy a new mobo and maybe a XP2100+ and then OC it if needed, BUT, I'm wondering if my PC133 RAM will transfer to a new mobo without causing any major performance bottlenecks?
My plan is to buy the Biostar M??? (can't remember its product code) for $60, drop in two sticks of my PC133 256MB RAM, buy a 2100+ Thoroughbred, add a GeForce Ti4200 (and OC it to 4400 or 4600 specs), and then use my SB Live, HD, floppy and the rest to go back into my Antec case....
I now the Biostar will support the PC133 RAM, but at what percentage of a performance cost? A 10% loss in overall system speed? More?
Also, is there an Nforce 2 mobo that supports 2 sticks of PC133 as well as DDR RAM? I'd love to go Nforce 2 with onboard sound and LAN WITHOUT having to buy new RAM. I have no budget for RAM unfortunately. (I just got another PC133 256MB for $10 fortunately - God clearly knows my budget 🙂 )
Anyway, I could use some help here and would really appreciate your suggestions..🙂
Thanks,
GS
Thanks,
GS
