How much of a noticeable difference will there be if I upgrade my Aureal Vortex sound card to
gnuel3
506
A SB Live! Value?
A Santa Cruz?
My speakers are the Altec Lansing 2.1 ATP3..
Sid59
11,879
Originally posted by: gnuel3
:-o! So my speakers are limiting it?
you ears might be limted too.
edit ...
if it sounds fine the way it is. save your money and don't upgrade. some people are just caught up on having STUFF. it's gloating. i do it too. =)
boyRacer
18,569
Nothing... trust me... nothing worth it at least. If my Vortex didn't crap out last week i'd still be using it... in goes a generic $5 soundcard and no freakin difference either... other than A3D... oh and i'll take Aureal over a live anyday. :)
gnuel3
506
Ah, I see. Thanks. :)
Is a Vortex really better than a SB Live? Wow, I thought the vortex was old..heh
Workin'
5,309
Yes.
It is old but that doesn't mean it isn't good. Now I think we are all assuming you mean a Vortex 2, not a Vortex 1. The only bad thing is that there is no longer any updated drivers because since Creative couldn't beat Aureal on merit they just bought them out and shut them down. Or something like that.
DaveSimmons
40,730
670
Also, sadly enough the DOS soundblaster emulation is much better on a Vortex2 than on a SB live.
lostatlantis
684
similar situation with me; my Aureal SQ2500 Vortex2 superquad is giving me problems under WinXP. I am guessing it's more of a driver issue than anything else. Is there any "good" XP driver out there other than Microsoft's that comes with WinXP?
Also, I've ordered a Audigy to replace the SQ2500... performance gain?
The SQ2500 now would probably replace my other system, a K6-2 550 running WinME and SB16 ISA :) What would be the "best" driver ?? I know there are a lot of modifications since Creative killed aureal, but it's a bit confusing and I don't know which one to use. I would appreciate it greatly if you can help~
