HOW MUCH MEMORY SHOULD I BE USING ???????
antonio131
19
JUST WONDERING WHAT EVERYONE IS USING ON THERE RIGS? I HAVE 256 BUT LOOKING TO UPGRADE TO 512 SHOULD I ? YES NO AND WHY PLEASE
Sugadaddy
Banned
May 12, 2000
6,495
WHAT OS DO YOU USE??????????
IF IT'S WIN98 OR ME, NO, IF IT'S WIN2K, THEN MAYBE IF YOU USE PROGRAMS THAT NEED A LOT OF RAM!!!!!!!!!!!!!
peemo
1,329
If you don't know that you need more memory then you probably don't. 256MB is good unless you runs many apps at the same time or are doing serious graphics work. Of course you can always buy another 256MB and try it. If you don't notice a difference just sell the RAM. It's a cheap test right now.
