How much mem is in your system ?? Poll
CubicZirconia
5,193
512 mb crucial pc 2100 ddr. 11 people have voted and no one yet has less that 512, I wonder if thats a pattern or a coincidence.
Miramonti
28,653
100
I have 256 in my 'older' machine, 768 in my main 'do everything' machine, and 512 in my 'only work' machine. 512 is great for XP - those who get by with 256 don't know what they're missing. :p
flood
4,213
256 noname pc133 in my main, 1.5gb crucial ddr in my server
Rand
11,071
640MB presently..... though I'm thinking it's about time I pop in some more.
Running anything very memory intensive in the background while playing Morrowind steals all my RAM in an instant. :(
Been starting to multi-task a bit more heavily then I did in the past, and when I have FTP proggy, FrontPage, and PhotoShop running simultaneously it gets pretty close to hitting the pagefile with regularity, and if I saw need to run Adobe 5, or my Scanning proggy, or even Corel at the same time I'll easily surpass the DRAM I have available.
Probably jump up to 768MB maybe a little more. I can't see myself needing 1GB as even my most intensive usage generally only sits around 800MB memory usage.
DKNG
88
I have 256Mb of PC2100. I'm running on WinXP right now. I see many of you guys having 512Mb now. So should I get another stick of 256 since it is cheap right now.
jdurg
215
512 megs of Micron PC2400 DDR RAM. On my old P3 1.0 GHz system, I only had 256 megs of PC100 RAM because I was running 98SE and had heard about problems with more than 256 megs of RAM. When I built my new system, I went with WindowsXP and went right ahead and got the 512 megs of RAM. After spending four years with 98SE and 256 megs of RAM, moving to XP with 512 megs is simply amazing. :)
splice
1,275
512MB, soon to be 768MB (just ordered another stick of Crucial DDR for $35, Thanks AnandTech Hot Deals People!)
Jittles
1,341
five hundred twelve megabytes of crucial double data rate memory pee see twenty one hundred
i8mywindpipe
222
I have 448MB of Century PC-133MHz SD-RAM
Notuced 448 wasnt an option :( :)
Picked up most of it (384MB) when RAM prices were waaaaay down
