I'm sure there is a thread like this somewhere, but I couldn't find it with the search string "arctic silver". I just recently got a new CPU fan so I decided to place some Arctic Silver 5 on it and try it out. Now the question is here, how much lower does this thermal paste reduce in temperature on your guys systems compared to using stock heatsink/fans. I couldn't find any data discussing this. I have an Intel 4 2.66 Ghz, Asus P4PE-X Mobo, and a Arctic Cooling Super Silent 4ProL cpu fan.
MB temp at idle: 31c 87f
MB temp at peak: 34c 93f
CPU idle: 43c 109f
CPU peak: 66c 150f
I haven't finished the "break-in" period, so I can understand if the temperature difference between now and with stock equipment is like nil. So what temps did you guys get to achieve on your systems?
CPU idle: 43c 109f
CPU peak: 66c 150f
