I used the APC calculator to determine how many watts I'd need for a UPS to support a system I'm about to build and it came out with 300W. Does that sound about right for this:
Cooler Master Real Power 550W
DFI LANPARTY UT nF4 Ultra-D
AMD Opteron 165
2XWestern Digital 3.0Gbps 250GB 7200RPM 16MB Caviar SE16
eVGA Geforce 6800GS
OCZ 2GB DDR SDRAM Platinum
NEC Black IDE DVD Burner
Creative Sound Blaster Audigy2 ZS
2X120mm Fans
And a 20 inch CTR (I could plug the CTR into a surge protector and leave just the PC connected to the UPS)
I'm looking at the Belkin F6C550-AVR UPS.
I'm also wondering if there is a way for the UPS to turn off the PC once it goes to battery power.
Thanks!
AMD Opteron 165
eVGA Geforce 6800GS
2X120mm Fans
Thanks!
