How much HD space can you account for?
CheesePoofs
3,163
Originally posted by: aplefka
Originally posted by: CheesePoofs
I normally keep fairly good track of my data. I've got a 160gb HD, but I just noticed that only 127gb are available for use. Where did the other 33gb go??
U make funnay?
no :(
Go to Disk Management, make a 33gb partition. Windows doesn't support big hard drives.
Windows does support big hard drives with NTFS; my friend is using a 250gb HD.
Edit: and where's disk management? (I'm on XP)
amol
11,680
Black Friday - November 25, 2005 :D
13.8GB left on my 20GB OS partition
100GB left on my 213GB Data partition (this is all because of BT and Goosemaster's HD clips :p)
mobobuff
11,099
U make funnay?
no :(
Sarcasm meter showing some activity...
amol
11,680
Next time I see an awesome deal on a big hard drive (UATA 100, those are cheap), I'll archive all my data on it and keep it as a backup
I'm a backup freak
amol
11,680
I'm pretty good at file management, but with all my backups before formatting, things havee gotten moved around here and there
After my AP test tomorrow, file managing is one of the things I plan to do
nsafreak
7,093
I try and clean certain file folders every now and then to free up space but when you have 200 gigs of local storage (a bit over 100 gigs free) and over 200 gigs available on network storage it can be hard to really focus on it that much since you do have so much space available.
Mildlyamused
231
Install SP1 if your using windows XP or SP4 if using windows 2000 and then enable 48bit LBA with the maxblast utility from the maxtor website (also be sure your mobo supports 48bit LBA).
shortylickens
80,287
17,081
Like many people here I have a relatively small drive for OS and programs.
And one bigass drive for junk.
Mine is a PATA 300GB Hitachi.
I keep smut and ISO's on it.
Mildlyamused
231
U make funnay?
no :(
Yes it does... It doesn't support it because of the fact that MS didn't implement 48bit LBA.. You have to enable it later..
Gurck
Banned
Mar 16, 2004
12,963
I'm still pretty neat about things with a pair of 120gb drives (no raid) in my main rig. Keeping a specific folder for downloads probably helps; I periodically go through it and decide what to hold onto and put it wherever it goes depending what it is, or delete it. My music collection is mirrored so I don't have to re-rip everything in the case of a hard drive failure.
RobCur
Banned
Oct 4, 2002
3,076
use the search function
do this,
*.mkv *.avi *.ogm
you should be able to find them all!
cerebusPu
4,008
i lost some personal photos the other day and searched frantically over 6 harddrives. my HD is overdue for cleaning and backup. Im tempted to just get a new drive and fill it up with the junk.
yhelothar
18,409
39
I have 500GB :)
I have no problem keeping track of what's on it, since most of it is gathered up in one folder called.. p0.. :p
WyteWatt
Banned
Jun 8, 2001
6,255
Hard drive organizing is just like house organizing.
You must purge then organize or then organizing won't do any good.
KarenMarie
14,372
i have 3x120gb and 1x80bg... they are all in disgusting shape. I move stuff, copy stuff, halfassed back up stuff... have partial deletes...
it is bad.
Umberger
1,710
i have 564 GB in this computer, and the thread inspired me to look. I have been cleaning for the past hour, and freed up nearly 20 gigs of space. I didnt know i had so much crap on here. Thanks ATOT!
drum
6,810
4
i'm prolly the biggest loser here with 140GB of pata. i just organized everything though.
SSP
17,727
This thread reminded me I have to clean up some backup files.
I have a pretty good idea of whats in my drives (160gig total, another 160gig drive thats dead now), but I have to organize them a bit better. I have directory structures like rabbit holes that I have to organize.
