- Mar 31, 2010
- 101
- 16
- 81
TL;DR  Is it worth getting the GTX 560 for my old system? If not, what model would you consider?
So I posted a while back about upgrading from an ancient 8600 GTS. Since then, I've saved enough to get something like this EVGA GTX 560 1GB 256-bit GDDR5.
But here's my uninformed question: Is it worth going as high in performance as a GTX 560 when you have an old PCIe 1.0 motherboard (LGA 775) and CPU (Intel Core 2 Duo @2.8 GHz)? If not, where do you draw the line? Thanks.
System Specifications:
Processor/CPU:
Intel Core 2 Duo E6550 Conroe 2.33GHz LGA 775 OC'd to 2.8 GHz
Current Graphics Card:
GeForce 8600 GTS 256MB 128-bit GDDR3 PCI Express x16
Display Resolution:
1680x1050 (native)
PSU:
Rosewill 600 W ATX12V v2.2 / EPS12V SLI Ready Power Supply
Case Specifications:
COOLER MASTER Centurion 5 CAC-T05-UW SECC, Chassis ATX Mid Tower
System memory:
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Motherboard:
ABIT IP35 LGA 775 Intel P35 ATX
Purchase Details:
Budget?
~$200
Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)?
No preference
Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
No
What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
Adobe InDesign, Planetside 2, Mechwarrior Online. Not picky about detail levels.
Do you plan on overclocking the card you intend to purchase?
Maybe a little. Nothing crazy.
edit: added sys mem and mobo specs
Processor/CPU:
Display Resolution:
1680x1050 (native)
PSU:
System memory:
Motherboard:
Purchase Details:
Budget?
~$200
No preference
No
