how much faster is 9500pro then 9500 non pro
titanz117
Banned
i need a videocard to finish my system
asus a7n8x delux
xp 1700
256mb pc2100 (for now)
30.7gb maxtor hdd
onboard nvidia soundstorm and dual lan so i can network this with my xp2800^
now the videocard issue. the max i want to spend is around 160. which is the pefect price cauz thats a 128mb 9500 non pro
i dont have teh 200.00 to spend on the pro so i was just curious how much slower is my 9500 gonna be is it equal or faster to teh gf4 ti 4400 im on right now.
im not intersted in chagning bios. i just want to know how much pefroamcne difference there is gonna be for me trying to save 40.00
The pro is quite faster than the non-pro if you're going to play at higher resolutions and it also has 4 more pixel pipelines enabled...
Yea the Pro is much much much better in my opinion and it is a close price range. And it will have much more longevity than the non pro. The 9500 pro is still owning up all all Nvdia card cept for fx 5800. Did I mention I'm a nvidia fan? 😉... Go w/ the pro bro.
damn.. first of all.. how the hell can u biosflash your nonpro to a pro if a pro has 4 more pixel pipelines than the nonpro (very important issue..!!) 2nd of all u can buy a 9500 pro at 190.00 bucks, i know its 30 bucks more than you're willing to spend but these 30 bucks will keep your card going a year more than it would with a nonpro 9500.. so for the sake of value, buy a 9500 pro
thats only for a certain type of non-pros. and those are hard to find
That is actaully very wrong you can softmod ANY non pro to a PRO. The ones that are hard to find is the non pros with a L shapped memory which you would be turning into a 9700 instead of a 9500 Pro. Either way go with a pro I bought my OEM 9500 Pro for $178 plus free ground shipping not a bad deal, at AllStarShop.com I think the extra 18 bucks is easily worth it. But you can buy a retail which comes with a $20 box too if you like.
From what I understand, it's the memory size that matters, not the card layout (though the layout may be related the the memory size).
The 64MB cards only have a half-bandwidth memory bus, same as the Radeon 9500 Pro, so that's what it mods into. But the 128MB cards have the full bus so can be modded into a 9700.
