How much extra power does your overclock consume?
ShawnD1
I've been screwing with my overclock settings and looking at power demand reported by my UPS. My processor is an E6600 which has a TDP of 65W. When I change the clock from the stock 2.4ghz to a nicely overclocked 2.9ghz, power consumption increases by 50W. That means I get roughly 20% overclock and it consumes 77% more power.
For those of you who have extreme overclocks like a 3.8ghz quad core, how much extra power does overclocking consume? Have you ever measured it?
On stock cpu voltage and clock frequencies (1.86GHz, 1.35V), my computer uses around 140W on idle.
Undervolting my cpu to around 1.125V saves me around 10W. For my 4830, using 300/450 MHz for 2D clock frequency saves me about another 10W, compared to 3D clock frequencies (800/1000 MHz).
Using 1.4V for cpu voltage and overclocking to around 3 GHz increases power consumption by about 20W over stock (on idle).
I think my system used around 240W or so under full load (orthos+furmark) when the cpu is at 1.86GHz, 1.125V undervolt. Total power consumption increases to just under 300W with my maximum overclock on the cpu (~3 GHz, 1.4V). In both cases, my 4830 is at 800/1000 MHz, voltage is fixed.
These numbers are approximations. I did actual measurements using my Kill-A-Watt meter, but I don't have the real numbers saved.
The increase in power consumption when overclocking shouldn't come as a surprise. It's why heat dissipation is such a huge issue.
I dont want to know, but i had to upgrade my 550W PSU because of instability, i went to a 850 for some breathing room.
That's pretty damn good. Check this out:
E6600 at 2.9ghz, 1.30V, video card is an 8800GTX at stock settings. I should get a frying pan shaped heatsink so I can fry some eggs 😀
lol u guys dont want to know how much nadeshiko eats.
let me put it to you this way.
IF she was a car, she'd be a Indy car. LOL..
Before the gulftown i was over 500W on full load.
Stupid X2's on Xfire eat a lot of watts.
I was curious about this so I tested my i5 750 at three different settings. For idle, I measured the lowest consistent power draw on the desktop, for load I used prime 95 64-bit with 4 threads on large FFTs and took the highest consistent power draw. "Real" voltages were measured using CPU-Z. Power draw was measured from the wall using my Kill-A-Watt. Details and results:
Current overclock - 4.0GHz (190x21) @ 1.35V BIOS, 1.344V by CPU-Z, no EIST, no C1, no C4,C6,C7, rest of set-up in sig
Desktop Idle - 123W @ 1.344V, Load - 267W @ 1.344V
Stock - 2.66GHz (133x20), Turbo on (2.8GHz load), "Normal" voltage set in BIOS, EIST on, C1 on, C4,C6,C7 on, RAM @ 1333MHz
Desktop Idle - 76W @ 0.848V, Load - 180W @ 1.248V
Undervolt - This is a quick and dirty undervolt I did while I was waiting for my Noctua cooler to come in when I first built the system (was on the Intel stock heatsink, which is a loud POS) - 2.66GHz, Turbo off, EIST on, C1 on, C4,C6,C7 on, RAM @ 1333MHz
Desktop Idle - 79W @ 0.976V (lolwut), Load - 138W @ 0.992V
Pretty interesting I'd say. Obviously, turning off power saving features kills the idle power efficiency of the chip, but it greatly stabilizes the overclock at lower voltages, which is a trade-off I'm more than happy to make. This chip is still much more efficient than my Q6600 was, and come this summer if the heat is a problem, I can always tinker around with the power saving settings at a lower overclock. Anyway, hope the data was insightful.
Interesting. I was playing with stress testing tools and watching the power draw on the UPS. Power draw in one particular set of tests:
Prime95 small FFT - 318W
Prime95 large FFT - 311W
Intel Burn Test - 265W
Some "burn" test eh? This computer has F@H running in the background all the time and power draw actually decreases when running the Intel Burn Test. I wonder if Intel supplying horrible stock coolers has anything to do with their stress test software putting nowhere near as much load on the CPU as a regular program like F@H does.
What I would love to see, is the usage of my I7 920@3.7 @100% W/HT, and both video cards @100% (my 24/7 usage). Just got another power bill, and with cheap hydro power, it was $325, and I have 3 systems (6 video cards) turned off.
