How much does it cost to replace a blown head gasket?
OS
15,581
might as well get a port and polish while the head is off. :D
CTrain
4,940
I think the part itself is very cheap but the labor thats involve is expensive.
alm99
4,560
oh yeah, its a 5 to 6 hour minimum job.
DurocShark
15,708
56
Seriously, you're looking at about $400 from a normal shop, much more from a dealer.
If you've got the head off another hundred bucks or so to have the head gone over, new valve guides, etc, would be a good idea.
poopaskoopa
4,836
I think I paid about $550-600 to fix a cracked head gasket on a 1986 Honda Civic way back when.
