How much does it cost to install a sun/moon roof into a car?
Joyride
1,782
I may be getting car soon without a sun/moon roof but I would really like one
How much does it cost and how long does it take a pro to do it?
Rallispec
12,375
10
not even sure it can be done to all cars, its going to cost a lot, and yes-- unless you want to go out into the garage with a hacksaw and some plexiglass.. your going to need a professional. :)
Ns1
55,420
1,600
alot, and you're probably gonna fuxor up the structural rigidty(sp?) of your car (or so i've heard)
PsychoAndy
10,735
um......i'm not sure if thats a smart DIY project......you'll have to cut a hole in the roof of your car, wedge in a pocket for the roof to roll back in (which will probly mean you have to pull the interior roor back and cut several inches of headroom from the passenger compartment), put in a motor with railings for the roof, and to make it all happen you'll need to be wiring switches to the motor and power supply.
oh, and dont forget getting gaskets and stuff to seal it all up with. you dont want a leak.
trmiv
14,670
18
It can be done (anything can be done if you've got the $), but it would probably cost more than it's worth to have a sun/moon roof.
freebee
4,043
Just about every solid roof car of sufficient size will accept a sun/moon roof option. Typical prices can range anywhere from 600-1000 dollars. There is minimal loss of structural rigidity if done properly.
...and Joyride why you posting so much?
Joyride
1,782
<< ...and Joyride why you posting so much? >>
Not sure really I just thought of a bunch of questions I want answered and thought I better post them now before I forget them
luvya
Banned
Nov 19, 2001
3,161
but this is one stupid question:(
Joyride
1,782
<< but this is one stupid question:( >>
What do you mean? If this was a feasable thing I would definetly put one in
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Id just spend the extra and get the sunroof when ya buy the car... Too much $$$ aftermarket...
