How much does it cost to have a ring made out of platinum?
kaizersose
1,196
platinum runs about $900/ounce whereas gold is about $500. you may want to look at white gold. looks the exact same as platinum, just a little softer for the price of gold. pm me if you have more questions.
rh71
52,844
1,049
We just shopped for wedding rings. We had to go with white gold cause platinum was upwards of $1k right now (for a pair). Something to do with the war... so he said. Other jewelers were the same. Are you looking for guy or girl's ring and what size ?
The extra cost of platinum wasn't worthwhile for us right now... wedding was expensive enough.
GasX
29,033
I just bought two platinum wedding rings for $900. Mine was 5mm size 10 (or so...) and my wifes was ermmmm smaller.
glen
15,995
The actual platinum must be less than $500 for the material in a ring.
So, how much does the custom work cost? another $500?
rh71
52,844
1,049
what size ? We wanted custom platinum and she was willing to give it to us for minimum $1300 for a size 6 (3mm) and size 8 (6mm) combined. In comparison, we ended up with white gold in those sizes for $540.
GasX
29,033
note - basic rings w/ no engraving are basically a commodity. Shop around by phone once you know your sizes because the range of prices is wide...
TMPadmin
1,886
Forgot how much the platinum was in our rings but we decided to go with it since we plan on keeping them forever and hopefully pass them down to our kids or grandkids. Mine is really taking a beating and still looks great!
Drekce
1,398
I have a platinum wedding ring. It is about medium size and was ~300 3.5 years ago.
Yaotl
444
ours cost a total of about $2k with the design and casting and material and everything else. and white gold does not look just like platinum.
nakedfrog
62,283
18,162
My GF and I are planning on getting married within the next year, and we've more or less decided to get our rings from this place. They've got titanium, tungsten, and some of them incorporate platinum/gold/silver.
Yaotl
444
we really wanted something that was just for us, hence the design fees and such. our rings only took about a month to get all done, maybe a little longer.
Jzero
18,834
Any luck with them? I e-mailed them a question last week and haven't heard back, which makes me a little sketchy about doing business with them, but I love their claddagh design. It's uncommonly masculine.
My real jeweller warned me that Ti is very hard to resize, but I counter that with it being cheap, you can just get a new one if your weight changes THAT much.
That was my mother's other point...my father is on his 3rd wedding ring. The first was cut off when he broke his hand. The second flew off in the ocean. She warned me not to spend too much on my wedding ring - men are hard on them and there is a good chance that it will be lost or destroyed.
That said, I'm going to get a cheaper ring for me and a nicer one for the wife-to-be.
Kaido
Feb 14, 2004
51,110
6,962
ooh :)
my fiancee and I went ring shopping in June...got a white gold ring, its really pretty (proposed in July, btw :)). she's not a big fan of the yellow gold. I'll probably end up getting a white gold ring, too. we haven't found one we really like yet tho. what are the advantages to platinum?
richardycc
5,719
goto diamondtalk.com, a few designers hang out there. white gold don't look like platinum, plat has a dark luster that you can't get from white gold, not to mention it feels a lot heavier than gold.
Trey22
5,540
Wife's platinum wedding rings cost $1100.
My silver band cost $99 (They way I treat rings, the cheaper the better).
