How much does it cost to get an A/C installed in a car?
wasssup
3,142
I just came across a used car that's in really good condition with low mileage and a great price (carfax shows its clean)..only pitfall is it has no A/C. If getting an A/C installed doesn't cost *that* much I may go for it (i'd rather get it installed at the dealer as their warranties are far better than mom-and-pop stores, or those crappy chains like R&S Strauss..).
BTW, the car is a '98 Civic HX..
tcsenter
18,909
559
AT least one grand.
Yep, probably between $1500 and $2000.
Best to scour the salvage yards and find the accessory brackets, hoses, radiator, condensor, compressor, AC climate control panel, etc. and do it yourself. Good luck!
T2T III
Originally posted by: tcsenter
AT least one grand.
Didn't Honda charge $1,300 or so for this option? I don't think I would invest $2,000 in the A/C - unless you desired to keep the car for a long, long time. You'll never get the that money back out of the car if you decide to sell it.
wasssup
3,142
whoa really? screw that, i couldn't live without an A/C :Q
thanks for the replies!
T2T III
I just re-read your thread. Initially, I thought you had purchased this vehicle, but after re-reading it, I realized you were just looking at the vehicle. There's plenty of other cars out there, so I'd keep looking if I were you. Not having the A/C probably only dropped the value of the car by $300 - however, getting new A/C installed would be much more.
Spamela
3,859
mine was about $1300 installed by the dealer when i bought a new truck (that didn't have a factory-installed one).
3rd party installers weren't that much cheaper and the warranty was only 1 year (versus 3 years for the dealer install).
it shouldn't be too hard to find a good used vehicle WITH A/C.
About $1,000 for the A/C kit from Honda plus installation.
(Installation about 6 to 9 hours flat rate at a Honda dealership)
