- Nov 4, 1999
- 24,125
- 508
- 126
I've just been looking at the prices of used SB mbrds & it seems I can get a mbrd for far less than £100
, looking on ebay they range from £25(!)-£60+, although I'm sure some have unsuitable chipsets, which chipset/mbrd should I be looking for to o/c a SB?
Also a cheaper alternative to the 2500k is the 2400/2380P which go for £80-£100, of course these are o/c limited (max 3.6 GHz) but the SB option is back in contention
Both Lynnfield & the above SB option would cost about £175 to £210 (CPU, mbrd & RAM, cheapest to average price).
With the i5 2400 having a max o/c of 3.6 GHz & the i5 860 (Lynn) approx. max of 3.8-4 GHz, the performance of those 2 would be close (looking in ATs bench, at the same clock the SB has a small overall advantage). So there I would be better off with the SB (primarily cos I could upgrade latter with a K & maybe an IB CPU) although that hinges on being able to get the right SB mbrd for £50-£60.
The Bloomfield setup would cost £215-£240 so that pretty much rules it out (unless I got lucky on getting a very cheap mbrd ...... that reminds me Mark made me an offer
RD
Got ya now
RD
Got ya now
