absolutely nothing.
Nothing for a cleaning - dental plan cover 100% of it
Since when do you have to clean them?!
Teeth do not require cleaning, its just something people do to remove the plague. Its mostly for cosmetic appearances.
My last cleaning was about 3 years ago, and before that my last cleaning was around 1985 or so. I "thought" I had a cavity, so I went to have it checked out. But it turned out to be nothing.
You have a family member that is a dentist and gives you free service or something?
How much is your dental plan? Mine is about $10/month. So $120 a year. For two cleanings a year, that comes out to be $60 per cleaning. This amount will be less if I end up needing fillings or x-rays and such, because those services would be discounted by my insurance plan and thus offset the cost. But that is hard to calculate off hand.
Teeth do not require cleaning, its just something people do to remove the plaque. Its mostly for cosmetic appearances.
how much do you pay for a teeth cleaning
Um yes they do. Plaque leads to tatar, which lead sto tooth decay. What do you think cuases cavities?
Very good John 🙂Plaque does, tartar does not. That said you can't get tartar without the plaque forming a bond to become tartar.
I have never seen anyone who did not need cleanings. Even those who brush/floss properly will still get some buildup. Heck, I'm an ace with a toothbrush and floss and I still build up a little stain/tartar between cleanings.In any case, you don't need cleanings if you brush and floss properly twice a day using a good toothpaste.
