I have an overclocked Celeron system with lots of hardware. I have DVD, CDRW, CDROM, 2 hard drives, ZIP drive, all PCI slots full and lots of fans. I used to have a 300W power supply. Although I wasn't really running into any PSU related problems, I opted to go the Enermax 350W PSU route cause it's better for cooling (dual fans) and quieter. Might I also add that it has the 12V connector that will be used exclusively on Pentium 4 motherboards so it'll be useful for the next generation of computer. I used to experience power fluctuations observed through Asus Probe. With the Enermax, the power readings are perfectly flat with NO fluctuations. Currently, I still have all the same hardware as above including 4 x 80mm case fans, Golden Orb, Blue Orb, slot cooler and HDD cooler. Lots of drain and the 350W Enermax doesn't budge. A great PSU if you have LOTS of power demand.
