Originally posted by: GiLtY
Depending on the resistance of your wire. in a closed DC loop, the Voltage = Resistance * Current. So lower the resistance bigger the current.
Originally posted by: masterxfob
ever stick one on your tongue? hehe, don't lie, i know everyone has tried it before![]()
JESUS!! Physics, I have failed you. V=IR, that was one of the formulas everyone should know. Thanks a lot! And I just went and already emailed energizer asking them what their output was.
i haven't, i'm too scared, i heard you get shocked.......though one time when i was little i grabbed an electric fence with both hands and my mom had to tackle me to get me off......maybe that explains it :Q
Well, it doesn't matter. Guess I'll be picking up some 200ohm resisters tomorrow at radioshack.
Thread got more replies then I thought. Me going to bed now.
[/i]
A battery does not have infinite supply though. Although the electrical equation may make it look like it could draw a lot of amps, the battery may not have the ability to provide that much current with the chemical reaction taking place inside of it.
Of course I have. I've also converted a good number to the dark side. Bwahahahaaa
No, but I'm messing with a lighting system and I'd like to not burn out all my leds and such.
That only works up to a certain point. If you do the equation and put in no resistance (such as a short circuit), it would say that the current draw is nearly infinite. But the battery will not be able to put out that much current.
Let's say he's designing a circuit and he does the equation and find out that it will draw 5 amps. When he plugs the 9v in, the circuit won't work right. Why? Because the battery won't produce that much current. Even with a dead short it will have a upper limit of how much current it can provide.
Originally posted by: So
That's due to the internal resistance of the battery, correct? (or is that just a fiction from high school phys?)
Originally posted by: FenrisUlf
If you regularly read Dan's articles (www.dansdata.com) you will see that he talks about batteries ALOT. A quick search there will probably yield more info about batteries than you ever cared to know. You can probably pull a few hundred mA off of a regular 9v, but remember that they're made up of six smaller cells inside, each only a fraction of the size of a AAA. At that current draw you'll severly compromise its lifespan and might not be able to get the full 9v.
Ok, I found some specs and played with the numbers. An alkaline 9v battery has an internal resistance of about 2 ohms. With a voltage of 9 volts and an internal resistance of 2 ohms, if we were to run a the battery in circuit with an LED on it (around 1 ohm), according to the formula the expected current flowing in the circuit would be 3 amps. But it's doubtful that a 9v will be able to produce that kind of current, for the reasons I mentioned above.
