how much clearance do i need on top of my monitor??
jjyiz28
2,901
as you know the top of monitor is where heat leaves the monitor, and it should be free of obstructions. i have a 1.25 inch clearance between my top shelf of desk and my monitor
here is pic
when i put my face to my monitor, i feel lots of heat comming out.
is this enough space??
sswingle
7,183
45
It'll be fine. If the monitor does overheat a little, it probably won't break it for about 10 years or so ;)
MasterHoss
2,323
Although more space couldn't hurt, you should be fine. There seems to be enough space for the heat to escape toward the back.
GonzoDaGr8
2,183
Your pic only shows the front of the monitor, the back where the vent holes are should have about 5-6" clearance. I would have to say you are fine. If it were fully boxed in, then I would worry.
