How much AS adhesive do I need to use in order to stick blue orb on northbridge??
heng1028
1,792
what is the best amount of AS adhesive to put in order to get maximum heat transfer from northbridge to a blue orb??
anyone knows??
WarCon
3,920
Here is the link to the application page. It has very important information about mixing the epoxy with arctic silver thermal compound so you can remove the thing later. If you never think you will need to remover just use it straight, well I will let you read the instructions from the horses mouth. Applying Arctic Silver Adhesive
