How much CFMs?
Ive seen some 41CFM@34db...(80mm), for a mere 3 bucks...also some quieter ones that pump less air
And- those fans with thermal sensor speed control things...u kno, they goto higher rpm @ higher temps. With those, what is generally a good "stepping"? Like is 85C-41CFM, 65C-33CFM...good?
or maybe...45C-43CFM@37db, 40C-39CFM@35db...etc
this is for a 1.2ghz AMD system...will probably OC to about 1.4+, so heat matters (i think)
thanks,
-eric
thanks,
-eric
