Hi all,
I managed to salvage enough PC-133 and parts to put together a htpc. I have a 1.33Ghz T-bird with 1.25GB of SD-RAM. This is all on an abit- kt7a raid motherboard. For cooling I have a thermalright SLK-800U with a decent 80mm fan. Currently Temps are around 46C once the rig has been on for a while. I wasn't into overclocking back in the t-bird days so I am not too familiar with the specifics of what this chip can take.
1) Whats temperature range should I be looking at? I know it will prob run a bit hotter than a thouroughbred or barton, but how hot is ok?
2) What is the recommended max voltage on air for this chip?
3) What is a reasonable OC on good air cooling for this setup?
4) For SD-RAM based Athlon rigs, what settings do the most good? Are mem timings that big of a deal? Would OC'ing the FSB(and hoping the PCI cards can take it) be worth it?
