- Nov 16, 2011
- 3,961
- 145
- 106
What's the typical wattage draw for a 120mm AIO cooler? I imagine the pump mechanism would draw more than the typical 120mm fans alone. Anyone run a kill-a-watt test?
I have the Kill-a-watt device. Never had the chance to measure the increased wattage draw of a single 120mm AIO.
However, here's a link to the spec sheet page of a COOLER Master 120M seiden. It appears total wattage used (I assume including the 120mm fan) is @ 3.7 Watts and the pump alone is 1.8 watts.
I stand corrected! I believe the pump alone uses up to 1.8 W and the fan up to 3.7 W so total for a single 120mm fan AIO @ 5.5W
http://www.coolermaster.com/cooling/cpu-liquid-cooler/seidon-120m/
Click on the spec tab for the link and read the wattage at the end.
I'm wondering why the question.
Thanks guys.
I'm doing my math to see if a Antec NEO eco 620 watt PSU will be able to power a pair of 7950's. Didn't want to overlook a possible power hog. Looks like the AIO pumps are very efficient. I would have thought they drew more wattage than that.
My back of the napkin calculations:
I'm running my 4690k processor at 4.3 ghz with 1.1v. Argus monitor puts it at around 60watts draw with full load. I'm guessing system minus GPU is somewhere around 120watts.
I'm running my single 7950 at 1ghz with 1.1v. Thinking the max draw would be around 150-200 watts.
That leaves me some room to put another 7950 in the system as long as I limit my voltage during overclocking efforts.
