How many transistors are in a led flashlight bulb?
Status
Not open for further replies.
Harvey
Administrator<br>Elite Member
73
Some led flashlights have 1 yellow square as light source, like this
http://www.flashlightslighting.com/...5/07/CREE-LED-XM-L-T6-Zoomable-Flashlight.jpg
How many transistors are in that 1 yellow square? Is it billions like cpu or is it 1 big single transistor?
No tranisistors are in the yellow square. That's the LED, and most of that is the plastic that houses the LED die. There is an IC within the packaged product that includes most of the circuitry necessary to drive the LED. One example is Texas Instruments TPS61090.
The packged IC:
Functional diagram of the circuitry in the IC:
One answer to the question, how many transistors are in the package is, "as many as it takes." Another is "all of them," because the IC wouldn't work if some of them got out. :p
Seriously, if you need this info, you could contact engineering support at any manufacturer of this type of circuit for a transistor count in a given product.
Hope that helps. :)
John Connor
22,757
619
121
I was amazed when I read in my electronics book many years ago when I was about 17 that a LED converts electricity directly to photons. Now everything has a LED or a MOSFET.
Mr Evil
464
187
mrevil.asvachin.com
An analogue controller like the one Harvey's post shows probably contains a few dozen transistors. If it's a more sophisticated model with a microcontroller then it might be 10s of thousands. A lot less than a CPU.
Jeff7
41,596
20
Back to the LED quick: That type of LED is likely a single emitter die.
As others have said, it's not a transistor, but it is a semiconductor material. It's a different material than a transistor, and it's doped with other elements to change the colors. There are two chemistries in common use for bright LEDs: InGaN and AlInGaP.
Indium Gallium Nitride makes blue and green LEDs, and AlInGaP makes red and yellow. (Almost yellow, anyway. It's kind of on the orange side though.)
A white LED uses a blue emitter and a yellow phosphor. Some of the blue excites the phosphor to produce yellowish light, and some of the blue passes through. To your eye, the combination of yellow and blue looks white. Manufacturers will vary the amount of blue and yellow light in order to change the way the color of the white light looks.
Small LEDs like that will often have a single die.
Larger white emitters can incorporate multiple dies in order to increase the overall brightness. The Luxeon's CoB lineup uses this method: Beneath the yellow phosphor are multiple individual dies.
That's done to keep manufacturing costs low: If a single huge die was made, a flaw in it would effectively mean the entire thing would be scrapped. Using small dies means that any flawed components result in very little scrap. In addition, the die can be a standardized design that is used in multiple products. A small LED would only use a single die.
The dies themselves are often tiny.
This page shows a photo of an LED that's roughly 3x3mm.
The dark square in the middle is the only part that makes the light. The rest of it is packaging to direct the light outward, make soldering easier, and provide a path to conduct heat away from the die.
Here's an example of an LED that has multiple dies.
The gold wires are "wirebonds" that make electrical connections for positive and negative.
Cvengr
8
LED = Light Emitting Diode
A transistor acts like a valve. One voltage is the Energy to be released when another voltage activates the transistor.
An LED uses the photoelectric effect to release energy from electromagnetic voltage into photons of a particular frequency.
Status
