How many processes do you have running right now?
CrazyHelloDeli
2,854
Originally posted by: Aelius
17 if I don't include Internet Explorer which makes it 18.
15 process If I turn off active Virus Scaning.
I'm running WinXP w/ SP1
This rig has been tuned for pure performance.
Edit: Technically I have 16 process running since Task Manager only runs when you use it.
Same here(17). I only run what im using at the moment.
AFB
10,718
MySQL
PHP
Apache
Winamp
Norton
IE
And about 5 other things.
Handles:16362
Threads:767
ultimatebob
25,134
2,450
28. I'm also running XP pro, with an Anti-Virus scanner and some wireless NIC drivers running in the background.
Gerbil333
3,072
I'm on my nForce 2 IGP computer right now though. My usual system (gaming rig) would have 18 processes going.
Edit: Wow, what do you guys have running? I know I'm almost as low as I could possibly go, but I've done less! I always make an effort to disable all start-up apps, and all I have running at the moment is a single IE browser.
If you don't know how to find this out, press(this works with XP and 2000 I think, not sure baout older versions of windows) Ctrl-Alt-Del, then click the processes tab and count them.
There's no need to count them. it's already written out at the bottom of the Task Manager window. It says "Processes: 16". Ctrl-Alt-Del is probably easier, but you may also launch Task Manager by right clicking on the task bar (start menu/quick launch/running apps/clock area) and selecting Task Manager.
vi edit
62,484
8,345
26. Task manager is one, AVG is 4, wireless nic config is one, AIM is one, IE is another. So I could get it down to 18 if I shut those down.
