- Mar 4, 2000
- 27,370
- 239
- 106
... This set me to wondering if there was any correlation between HDD failures mentioned here and the particular use of the computer or housing in which they're fitted. It would seem likely that HDDs in laptops and external HDDs would be much more often suffer physical shock during their lives than those in fixed desktop PCs.
A consequence of this might be why bigger Seagates, because they're relatively cheap and therefore bought by the mass market when wanting external storage at a good price/capacity ratio, are reported failing more often than some other brands.
You bring up valid points to consider. I do believe that large drives, i.e., >greater than 500GB, are more prone to failure. And, I do believe a lot has to do with how they are used and maintained.
