How many garage doors should I put in a 2 car garage?
Discussion in 'Off Topic' started by Scarpozzi, Nov 13, 2012.
  1. Scarpozzi
    Scarpozzi Lifer
    Jun 13, 2000
    22,529
    60
    1 or 2?
    Just wondering what the consensus is on this. I'm planning a remodel and have a 20x20 carport. I'm going to put up 2 new walls and make a 24x20 garage (24 long and 20 wide).
    Anyone got pros and cons about 1 door versus 2?
    Thanks.
  2. Kelvrick
    Kelvrick Lifer
    Feb 14, 2001
    18,442
    2 doors pro:
    1 garage door opener
    cheaper initial cost in hardware and installation
    more "wiggle" room to get in or out
    car can be parked in the middle for many uses (maintenance or just large vehicles)
    1 door pro:
    i think it looks better
    can be opened 1 at a time
  3. sygyzy
    sygyzy Lifer
    Oct 21, 2000
    14,001
    I am not sure if you did it on purpose but do you have your list swapped?
  4. skyking
    skyking Lifer
    Nov 21, 2001
    17,957
    135
    Most 16' doors are not good, they will eventually sag.
    Is this a remodel with a permit?
    If so, you will need shear walls at the front corners. The alternate shear wall in the UBC is ~20" finished.
    240" - 40" = 200" = 16' 8"
    So there is the dilemma. Two 8' doors are a PITA as well if you have a full sized truck. You have to fold mirrors to go in or out.
  5. Cookie
    Cookie Golden Member
    Jul 3, 2001
    1,760
    I had that same dilemma a couple years ago. Mine was 24' wide and I chose the 2 door option. The only major problem I have with it is visibility when exiting. I back in to the garage, but even then, when I exit, my car is a few feet into the alley before I can see if anyone is coming. May not be an issue in your case.
  6. sdifox
    sdifox No Lifer
    Sep 30, 2005
    68,004
    2,621
    1 prefer 1 door. More flexibility on space.
  7. sdifox
    sdifox No Lifer
    Sep 30, 2005
    68,004
    2,621
    I think your got 2 doors and 1 door confused :biggrin:
  8. AdamK47
    AdamK47 Lifer
    12,586
    346
    At least 3
  9. IronWing
    IronWing Lifer
    46,893
    3,040
    Six, two on each of three sides. Will allow you to open up to let in air and light.
  10. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    47,430
    1,073
    Go for the funky 70s look, and use a bead curtain. It's easy to install, and you can make dramatic exits.
  11. KaOTiK
    KaOTiK Lifer
    Feb 5, 2001
    10,884
    I second the bead curtain.
  12. SagaLore
    SagaLore Elite Member
    Dec 18, 2001
    24,034
    12
    2 bead curtains.
  13. Sluggo
    Sluggo Lifer
    Jun 12, 2000
    15,491
    No disco ball, or does that kind of go without saying? :cool:
  14. Northern Lawn
    Northern Lawn Platinum Member
    May 15, 2008
    2,231
    I live in Winnipeg and park outside like a man.
  15. T_Yamamoto
    T_Yamamoto Lifer
    Jul 6, 2011
    13,864
    9
    no garage door
  16. Triumph
    Triumph Lifer
    15,031
    10
    1 big garage door if you can do it. much more practical. i myself am happy to have a garage at all.
  17. olds
    olds Elite Member
    Mar 3, 2000
    48,863
    86
    No brainer
  18. 3chordcharlie
    3chordcharlie Diamond Member
    Mar 30, 2004
    9,861
    I'd say one door if possible. 9' doors are alright, 8' is pretty restrictive for any sort of larger vehicles.
  19. Doppel
    Doppel Lifer
    Feb 5, 2011
    13,313
    Because you're too poor to have a garage.
    Go for one door. It looks better, only one opener to worry about.
    I would think that sagging is a non-issue if you have it done properly. I just perused mine and it's a 16' engineered joist across the span, at least a foot high (not sure how thick the joist is). I can't see it ever sagging.
  20. herrjimbo
    herrjimbo Senior member
    Aug 21, 2001
    784
    you also have to take into consideration, with 2 doors there's going to have to be a small wall between them at the entrance. probably about a foot wide.
    i have a 24 x 24 garage and an 18' door. there is no sagging as it's reinforced due to it's size.
  21. Sluggo
    Sluggo Lifer
    Jun 12, 2000
    15,491
    That is required by code now just about everywhere for the larger garage door openings.
  22. imagoon
    imagoon Diamond Member
    Feb 19, 2003
    5,199
    20 year old 16 foot door here only started sagging when my sister drove in to it.... I prefer the single because I can pull a car in the middle to work on if I need to.
  23. DesiPower
    DesiPower Lifer
    Nov 22, 2008
    14,966
    339
    I dont think a 20x20 will have enough space for 2, I recommend one
  24. Schfifty Five
    Oct 20, 2005
    10,842
    22
    2 separate garage doors look better, but harder to get in/out of than one big garage door.
  25. Kelvrick
    Kelvrick Lifer
    Feb 14, 2001
    18,442
    ***. Thats what I get for staying that late at work and still posting on atot.
