2x 80mm rear exhaust
1x 80mm blow hole
1x 80mm side intake
1x 120mm front intake (disabled... friggin vacuum cleaner noise)
1x 80mm on the Volcano 11+ HSF
1x 40mm stock fan on vid card
1x ThermalTake Silent Boost (running at 1700RPM with a fan controller)
1x Antec 120mm exhaust running at 5V
1x Thermaltake 120mm intake running at 5V
1x 80mm Antec PSU fan
No fan on the video card (using Zalman heatpipe)
Runs pretty quiet! Almost inaudible standing a foot next to it!
PC#1:
PSU = 1 x 80mm panaflo l1a
CPU = 1 x 80mm panaflo l1a
Intake 2 x 80mm panaflo l1a (mounted on side of case: one above the cpu and one above the video card)
PC#2
Outtake = 1 x 80mm panaflo l1a
Server#1
PSU = Antec 60mm
3x80mm
1x 70mm in the CPU 4500rpm, a jet engine... no so good at CFM, but a jet engine, no doubt
1x 40mm in the video card (GeForce 4 MX440)
1x 40mm in the chipset NorthBridge Via KT133A
Let's see:
PSU 1x92mm, 1x80mm (True430)
Case 2 x 80mm (1 Panaflo L1A) Side Panel fan disconnected.
CPU fan 1x 92mm 33dBA fan
Vid card fan (60mm I think)
