I have been running an Intel E8400 cpu on a Gigabyte EP35c-DS3R motherboard. The motherboard failed recently, and is being replaced by Gigabyte with their EP45-UD3R motherboard.
The old motherboard had a single 4-pin cpu power connector, while the replacement board has 2x4-pin connectors. My power supply, a Corsair HX650 has two 2x4-pin connectors which can be used either together or singly.
What is the proper way to connect the PSU and the motherboard? Is it to use both connectors or is one sufficient for the cpu?
Thanks for the advice.
