- Sep 27, 2008
- 495
- 1
- 81
How many of these http://www.sidewindercomputers.com/thec6noncoco.html do i need if i have 275ml reservoir and Feser 480 Quad Radiator
HK 3.0 Acetal top CPU Block
Bitspower N/S Chipset
Bitspower Mofsets II & III
Bitspower compression fittings (reg)
D5 vario pump
feser Quad480
feser White tubing
Just flush your coolant every 6 months, and you may want to add a bit of silver.
http://www.petrastechshop.com/sikibyia.html
That should be all u need.. and yes the silver is reusable.
www.petrastechshop.com said:Warning: This product contains...uh...Silver!
If ingested, you may choke... so just don't do that.
If contact with skin occurs, smile... you're holding silver!
AVOID CONTACT WITH EYES! If contact with eyes occurs... wait, why are you shoving metal coils into your eyes?
Do not mix anything with that if you have already bought it, especially water, distilled or otherwise. The whole point of paying $15-20 for a single liter of cooling fluid is that it is non-conductive (I had a faulty bitspower fitting recently, glad I was using Feser One F1). The price itself isn't all that different anyway once you consider the price of the distilled water, corrosion inhibitors, algae inhibitors, dye, etc.
kewl. what about the Feser corrsion blocker fluid? it came with my radiator. I can mix it with distilled water? Or because i've already have purchased http://www.sidewindercomputers.com/thec6noncoco.html just use until next fluid change? and YES is heck of alot cheaper going with distilled water.
First, Feser fluid is no less conductive than pure distilled and may really be more conductive in actuality. Don't tell me you've fallen for Feser's "demonstration" of their non-conductive fluid with the fan submersed and running in their fluid, have you?
I'd guess (and it's just a guess) it would regain conductivity from contaminants more easily than a fluid such as Feser F1.
I never argued he shouldn't use distilled water, but apparently some failed to read he had already purchased a bottle of Thermochill non conductive coolant, why would he waste it now?
But he is mixing metals. Almost all loops have different metals. My blocks are Nickel, my CPU block is copper, my radiators, who knows....
Loop
Tubing PrimoFlex Pro LRT UV White Tubing -3/8in. ID X 5/8in. OD (10ft)
Coolant Feser One Non-Conductive Water Cooling Coolant (2 x 32 oz.) - UV Red
Reservoir XSPC 5.25" BayTwo Black Reservoir Bay w/ Red LED
Pump 2 x Swiftech MCP350 12 VDC Pump
Radiator 1 HardWare Labs X-Flow Extreme III
Radiator 2 Feser X-Changer 120
Radiator 3 HardWare Labs GTX Xtreame M184
CPU Block Swiftech GTZ
Fittings Bitspower Compression Fitting-ID 3/8" OD 5/8" (x5)
Fittings Bitspower G1/4 Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8" (x7
Fittings Bitspower G1/4 Dual Rotary 90-Degree Compression Fitting-ID 3/8 OD 5/8" (x1)
Misc Parts Bitspower Acrylic T-Block, Bitspower Temp Sensor, Bitspower Male to Male G 1/4 Fitting
Fans ******** White ISG Fan12 120mm (x5)
Fans Skyth Kraze 90mm 2000RPM (x2)
Thanks WoodButcher :$
BTW If you have iron in your system you deserve the rust?
I guess some impeller shafts are stainless steal,
Silver KillCoils. Is it safe to put it in one of the inlets in the pump? i have d5Vario.
