- Mar 18, 2007
- 11,959
- 156
- 106
Originally posted by: PurdueRy
+12V1@20A, +12V2@20A
Ok but can +12V1 and +12V2 be combined if something needs more than 20 amps or will the Power Supply do this automatically?
When they rate a motherboard or something as needing 30A on the 12V rail they are figuring that there will be many other devices using the 12V power. Having 2 rails reduces that load and therefore that rating is really not relevant anymore.
Reply with your hardware specs and people here can give feedback as to whether this will power it or not.
LIAN LI PC-61 USB Black Aluminum ATX Mid Tower Computer Case with 4 80mm fans
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card
ENERMAX Liberty ELT400AWT ATX12V 400W Power Supply
GIGABYTE GA-965P-S3 LGA 775 Intel P965 Express ATX Intel Motherboard
GeIL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
Intel Core 2 Duo E6420
Will that power supply in my first post link run this pc fine please? If so how much room for upgrading will the power supply has as well would you say? A lot, medium amount, or very little?
It should work fine. I would say you have a medium/small amount of headroom depending on how many hard drives you will have and if you have other add on cards you didn't mention.
Yes I will be adding 1 maxtor 200 gig 7200 rpm hard drive, I think my santa cruz sound card, inless I just want to use the onboard sound card though I don't think, and my NEC DVD-RW drive. I may add my old plextor cd-rw drive as well. Only maybe though. I don't think I will though. I may just keep it for my old pc that I will make into a hptc with a horrible case at the moment. So I may take out the tv tuner card and instead put it on the old pc I am on now. So that should free up a little bit of resources but not a noticeable amount I am sure.
Should that be ok ?
What if I want to upgrade in the future how much room do I have?
Should that be ok ?
You can use a power supply calculator and see how much more you could add. Just search google for extreme power supply calculator and you should find it. It seems that you might be pushing the border if you add that much more. However, you should still be fine for the configuration you currently have.
Originally posted by: jonnyGURU
The maximum combined capability of the +12V rail is only 30A.
This particular unit actually has split +12V rails with a 20A OCP that will trip the PSU when exceeded. This unit has no capability to "merge" rails in the event of an overload.
I personally think you'll be stressing that PSU out with the 8800GTS. It works now, but it probably runs pretty hot, no?
Are you sure its 20Amps ? Its not 30 Amps?
Each of the 2 12 V rails can deliver up to 20 A. Additionally, the current drawn from both rails combined can be up to 30 A. But you wouldn't be able to get 20 A out of both simultaneously (for a total of 40 A).
Ok so will the video card in my system specs work fine with this Power Supply or will the system be unstable or not boot up ?
