ch33zw1z
- Nov 4, 2004
- 37,766
- 18,045
- 146
Your buckets tho
I see your out of actual substance again. Shocking.
Your buckets tho
The world is doing a bad job. You’re so fixated on blaming Trump, you’ve ignored everything else.
Take the New Rochelle cluster. One attorney was at the heart of it. He had no direct contact to any hot spot. Developed symptoms but not enough to stop his daily routine, and rapidly spread it in his immediate community through communal gatherings.
The Washington state elderly care facility got hit due to a party.
You’re so fixated on testing, when testing assumes people will go to get tested when experiencing mild symptoms. If anything, more extensive testing would probably stop the hysterics, because the mortality rate will go way down once we know how many people actually have it.
Since the 1st documented case was in China I would have expected spread in those areas because they were first. Once the spread started in China we should have learned from what already happened and take action we did not. Here is a story that broke yesterday from one of the early outbreak areas in the US. Seattle tried early on to test but was blocked by the federal government. Eventually they tested without an ok from the Fed. Results came back positive but by then it was too late.As I have said repeatedly, and numerous news agencies are reporting, there is a debate between Trump and the CDC on balancing protocols with panic.
What didn’t?
Better at what? We’ve been told repeatedly that our health care system is inferior to most of the western world. The rest of the western world is weathering this no better than us.
Dr. Fauci made a public statement saying otherwise
There have also been wildly inconsistent projections on mortality rate as demographic data comes in for Wuhan and other places, not to mention that testing assumes people go to get tested, which is not happening for people only exhibiting minor symptoms. There was initial optimism that this thing was simply a bad flu. Go to any pharmacy or big box store. People are panic buying. Imagine what will happen if there is something to panic about.
You’re Monday morning quarterbacking and politicizing a pandemic. Pathetic.
Despite all of your counter points, you have yet to explain why its still spreading in other parts of the world. This is a global pandemic. As always, you’re solely fixated on Trump. Hence, TDS
You didn’t respond to my point about our response relative to global examples. TDS Monday morning quarterback. Pathetic.Since the 1st documented case was in China I would have expected spread in those areas because they were first. Once the spread started in China we should have learned from what already happened and take action we did not.
BTW - You still have not answered the question about Trump outright lying in real time in the same room as Dr, Fauci. Why when pointing out Trump is continuing to lie this time about life and death that is politicizing? It's just like the old tired canard pointing out racism makes you the real racist.
Why are you willing to accept Trump lying right to your face?
These 3 in particular were known by government scientists to be false yet Trump proclaimed them anyway. Why is that kind of lying from a President acceptable to you?
He said a vaccine will be ready in just a few months. It won’t. (In the same room as Dr. Fauci)
He said the number of Americans afflicted is going down. It isn’t.
He said anyone who needs a test can get one. They can’t.
However I'm sure your standards will shift back to normal once Trump is out of office. Pathetic
You haven’t addressed every example I’ve provided that breaks your narrative.I suspect this is just like the other threads where you will keep repeating yourself forever as opposed to changing your mind to fit the facts. This much was obvious when you said it was spreading at the same rate as in other countries while also admitting we have no idea as to the rate it is spreading.
The US response is very bad, marked by incompetence, lies, and deliberate misinformation. If you want to deny reality so you can do some sort of global #bothsides then knock yourself out.
How does that tactic get you through in life. Well so and so fucked up so you can't criticize me.The world is doing a bad job. You’re so fixated on blaming Trump, you’ve ignored everything else.
No example breaks my narrative because the question isn’t if any other nation also handled it badly but if we are handling it badly, and we are.You haven’t addressed every example I’ve provided that breaks your narrative.
If you want to Monday morning quarterback a global pandemic with TDS, knock yourself out.
I answered you question about other responses. Note South Korea.You didn’t respond to my point about our response relative to global examples. TDS Monday morning quarterback. Pathetic.
Leave the poor straw people alone! I refer you to the story of the boy who cried wolf.How does that tactic get you through in life. Well so and so fucked up so you can't criticize me.
If you concede that others are handling it poorly, the stubborn fixation to blaming Trump can only be attributed to one thing.No example breaks my narrative because the question isn’t if any other nation also handled it badly but if we are handling it badly, and we are.
You are accusing everyone else of being irrationally biased because that’s all you have. You already outed that your opinion isn’t based in facts when you claimed US infection trajectory was similar to other countries when we have no idea of what our infection rate is and the death toll indicates total infections are much higher.
If you want to convince yourself that all these facts are really just deranged liberals being mean then go ahead. I know you’re not amenable to rational argument when you get your back up like this so that’s the end of the discussion from me.
I have.I answered you question about other responses. Note South Korea.
Now try answering mine.
When others introduce inconvenient facts, you dismiss them and pull the usual schtick. Backed against a wall indeed.
At the same time, however, it is important that the president’s defenders not be blinded by partisanship of their own into excusing failures of leadership and diminishing the danger of the epidemic itself. This can be particularly difficult because some of the most significant inadequacies of the administration have been the president’s own. So far in this crisis, Donald Trump himself has obviously failed to rise to the challenge of leadership, and it does no one any favors to pretend otherwise.
and you are derangedWell handled outbreak:
Poorly handled outbreak:
Guess which one the US looks like:
United States COVID - Coronavirus Statistics - Worldometer
United States Coronavirus update with statistics and graphs: total and new cases, deaths per day, mortality and recovery rates, current active cases, recoveries, trends and timeline.www.worldometers.info
Apparently pointing out reality now means you hate Trump. lol.
Why is the National Review playing politics with COVID-19??The National Review has apparently come down with a case of TDS:
President Trump Needs to Step Up on the Coronavirus | National Review
So far, he has obviously failed to rise to the challenge of leadership. It does no one any favors to pretend otherwise.www.nationalreview.com
thats mindbending ignorant.Then explain why its spreading in countries that have been completely transparent, but also with initial mistakes. Even the Germans acknowledge that Italy getting hit first allowed them to proactively mobilize.
When all is said and done, the resiliency of our healthcare infrastructure and not Twitter will determine the death toll.
During a Tuesday press conference, Trump sought to reassure the public, saying everything from "it will go away, just stay calm," to stating the U.S. has done a "very good job" in testing for the virus, reports CNN's Daniel Dale.
Trump is discouraging facts and encouraging falsehoods. 10's of millions listen directly to him. he's been discouraging trust of the media for as long as he's been around, as well as government. This will impact the spread, no question. Your feels tho
He is really is walking into that good night kicking and screaming.... screaming fake news and kicking his own shadow. What a perfect moron.Agent Orange wants DOJ to investigate media coverage of the coronavirus.
“He’s Definitely Melting Down Over This”: Trump, Germaphobe in Chief, Struggles to Control the Covid-19 Story
Publicly, he sees it as yet another (“Fake News”) media war; privately, he worries about virus-carrying journalists on Air Force One. But cancel his rallies? “I’m not going to do it,” he says.www.vanityfair.com
I'm assuming Barr will do it. You help to keep installed and back a dictator, you do moronic dictator fetch quests.
The type of leadership you expect from the President
an annual observance intended to promote a dialogue about the importance of open government and freedom of information.
