How low can I go?
imported_Shivetya
the requirements hardware
300g of disk
dvd burner
printer connection (usb)
the requirements software
iTunes always on (to serve other iTunes clients in house)
How low of a power supply can I go before I get into troubles?
I have the following system I can rip apart.
3800x2
2gb ram (ddr)
6150 nvidia board
350watt power
can I reduce the power supply? I want to leave it on all the time without becoming a space heater. Should I just get a whole new processor/mb combo that eats a ton less wattage?
power supplies only use the amount of power necessary. They dont run at 100% all the time.
If all its going to do is work with music, might at as well pick up some crap computer off ebay , slap on a linux distro with a jukebox and enjoy the tunes.
